Blue-Ray Disc are good back-up media @ 25G or 50G. Thats what i use to save my system image files. Few disc needed instead of multiple DVD.
I save recorded HDTV Shows/Movies and Blue Ray disc come in handy. Also i save multiple DVD-movies on a single Blue-Ray Disc.
My LG Blue-Ray/HD-DVD Player Blue-Ray/DVD Writer is one of the most reliable optical drive i have. I only use one optical drive in my system. Optical drives are under-utilized for most part.
Blue Ray writer is ~ $199.99 to date. Blue Ray player is almost half the price.
Use the money somewhere else if you are not sure of what you need.
If you just watch blu-rays, then all you need is a standard BD-ROM. However, if you burn high-def movies, then you'll want to get a BD-RE, which also plays blu-rays.
-------------------------------Kevin
Desktop: Q9400(stock,lapped,SpinTechQ)/Intel DP43TF/VTEK 4850(512)/8GB DDR2 800Mhz/X-Fi Titanium Pro/Liteon BD-ROM/Velociraptor/Windows 7 Pro 64-bit
Laptop: Little Toshiba Satellite (M305)/T6400/4GB DDR2 800Mhz/Windows 7 RC 64-bit (for now
Reply to buwish
