I have a fairly new machine with an Antec Three Hundred Mini-Tower and "Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz" and Hitachi 1 TB sata 7200 RPM and 4 G RAM. This case is supposed to be quiet, but sometimes I hear the hard drive quite clearly. My coworker, in the next desk, even said once, "Is that your hard drive?" OK, her chair is only about 3 or 4 feet from mine, but I think this is not normal.
I run ArchLinux and Xfce and I think this machine should be FAST. Now I understand that Firefox can be a real resource hog, but even so, sometimes this machine literally crawls. Not sure why either.
Seems my disk tests well:
[fixed][dirk@arch]$ df -k
Filesystem 1K-blocks Used Available Use% Mounted on
udev 10240 0 10240 0% /dev
run 10240 116 10124 2% /run
/dev/sda2 432554256 61911892 348669864 16% /
shm 1673556 288 1673268 1% /dev/shm
/dev/sda1 93307 32840 55650 38% /boot
/dev/sda3 522916084 152983284 343370128 31% /home
[dirk@arch]$ sudo hdparm -Tt /dev/sda2
Password:
/dev/sda2:
Timing cached reads: 9726 MB in 2.00 seconds = 4866.41 MB/sec
Timing buffered disk reads: 418 MB in 3.00 seconds = 139.16 MB/sec
[dirk@arch]$ sudo hdparm -Tt /dev/sda3
/dev/sda3:
Timing cached reads: 9348 MB in 2.00 seconds = 4677.45 MB/sec
Timing buffered disk reads: 360 MB in 3.00 seconds = 119.89 MB/sec [/fixed]
So I'm guessing that anyway the noise is NOT good and I should return the drive (the store said he will replace it no problem) and that maybe that's why it's sometimes slow.
I did this also:
http://ryanschwartz.net/2009/03/19/adventures-in-firefox-placessqlite
and it helped, but still the machine is slow sometimes. VERY slow.
Any thoughts are appreciated.
Thanks.
Password:
/dev/sda2:
/dev/sda3:
I did this also:
Thanks.
