Tom's Hardware > Forum > Homebuilt Systems > New System Build > Will this build work?
Sponsored Links
It's an ok build but make these changes:
XFX HD-485X-ZDFC Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported
http://www.newegg.com/Product/Prod [...] 6814150351
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal
http://www.newegg.com/Product/Prod [...] f3%20500gb
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC
http://www.newegg.com/Product/Prod [...] 6817341017
Antec Two Hundred Black ATX Mid Tower
http://www.newegg.com/Product/Prod [...] 6811129070
Finally, have you considered AMD AM3?
Some more info would help as well...
http://www.tomshardware.com/forum/ [...] ild-advice
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
Thank you for the opportunity to click all those links for you
Reply to Outlander_04
^+1 LOL!!!
Okay back to the post... what is the nature of your business... meaning what do you do that you need to have a GPU over onboard? If you truly don't require a GPU, believe it or not, I recommend going with a Dell Vostro system... http://www.dell.com/us/en/business [...] =bsd&cs=04 . This is what I use at my work and it performances great for office work... now if you are doing "Graphics" than jbakerlent's comments should be taken into account.
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Whoops, just clicked the links, didn't read about it being used for office work... doh. Yes, in that case, a number of changes could be made. After you edit to use the sticky it will be easier to help you.
Reply to jbakerlent
There are 1171 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
