Tom's Hardware > Forum > CPU & Components > Sound Cards > Hissing sound in speakers dell xp PCI sound card
Forum CPU & Components : Sound Cards - Hissing sound in speakers dell xp PCI sound card
Dell Dimension XP computer. Suddenly a constant hissing noise in the speakers, same if I hook up headphones to the speaker board hole in the back of the PC.
Sound card is X-Fi PCI Sound card.
Speakers Dell A525 Speakers
Sponsored Links
Check first if the hissing sound exists on other sound output devices (like earphones or headphones). If it still continues, you may want to check if you're using updated drivers. Lastly, check if you're on analog or digital audio (go to control Panel > audio)
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
There are 546 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 -pcaddict- won the Freshman badge
  • 01:00 impreza won the Freshman badge
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
