Tom's Hardware > Forum > Homebuilt Systems > New System Build > Check me for compatibility on i7 920 Asrock x58 Extreme system
Forum Homebuilt Systems : New System Build - Check me for compatibility on i7 920 Asrock x58 Extreme system
APPROXIMATE PURCHASE DATE: On order.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Photoshop, Pinnacle Studio 11, Illustrator, InDesign,
PARTS NOT REQUIRED: keyboard, mouse, monitors, speakers
PREFERRED WEBSITE(S) FOR PARTS: Ordered from Newegg already
PARTS PREFERENCES: Intel i7
OVERCLOCKING: No SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1600 or less
ADDITIONAL COMMENTS: Need dual monitor support. HP LP2065 and Samsung SuncMaster 226cw
Here's what's on order:
($279.99) CPU INTEL|CORE I7 920 2.66G 45N R - Retail
http://www.newegg.com/Product/Prod [...] 6819115202
($56.35) ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler - Retail (with 1366 clip support kit)
http://www.newegg.com/Product/Prod [...] 6835118019
($169.99) MB ASROCK X58 EXTREME 1366 RT - Retail
http://www.newegg.com/Product/Prod [...] 6813157163
($124.99) MEM 2Gx3|OCZ OCZ3G1600LV6GK R - Retail
http://www.newegg.com/Product/Prod [...] 6820227365
($104.99) CASE ANTEC|NINE HUNDRED BK RT - Retail
http://www.newegg.com/Product/Prod [...] 6811129021
($229.99) HD 300G|WEST DIGITAL WD3000HLFS % - OEM
http://www.newegg.com/Product/Prod [...] 6822136322
($99.99) PSU CORSAIR|CMPSU-650TX 650W RT - Retail
http://www.newegg.com/Product/Prod [...] 6817139005
($49.99) DVD BURNER PLEXTOR | PX-880SA SW R - Retail
http://www.newegg.com/Product/Prod [...] 6827249051
$64.99) EVGA 01G-P3-N959-TR GeForce 9500 GT 1GB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814130395
and a few 18" to 25" SATA II cables.
Am I missing anything? Any problems with the above? I'd rather find out before I start opening boxes. Thanks!
Sponsored Links
Did you order thermal compound? This is the only thing I see missing.
I wish you hadn't ordered the parts already. I could've saved you close to $200
WD Black 640GB instead of VRaptor ($150+ savings) for close to the same speeds
Samsung DVD Burner instead of Plaxtor ($20 savings)
Xigmatek Dark Knight instead of CPNS9700 ($10 savings) for better cooling
You could've went with a 550w PSU but I'm okay with the 650w PSU in your system.
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Yes, thermal compound comes with the cpu cooler.
WD Black instead of VRaptor? $150? I might have to return one for the other.
And I looked for the Xigmtek Dark Knight, but didn't find in at Egghead where I got all the rest of my stuff.
Great feedback, thanks! This is only my 2nd build, so I'm not quite so confident of myself yet.
------------------------------ Scott See
J. Hammock & Associates, LLC
Reply to scott_see
- 0 +
Here are the Newegg links to my recommendations. I forgot to include them in my original reply...
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail $44.98
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM $74.99 As you see, you payed $230 for a HDD, when you can get one for $75 that performs almost as good as the VRaptor
Reply to tecmo34
- 0 +
CPU HSF Cooler
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail $44.98 Free Shipping*
http://www.newegg.com/Product/Prod [...] 6835233029
Reply to Yoosty
Got it. Just ordered the Caviar Black and the Xigmatek. I'll still be ahead of the game even after a 15% restocking fee.
Reply to scott_see
There are 436 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
