Hey everyone, im looking at building a fairly expensive overclocking rig, and ive typed up a draft of a Koolance setup - if anyone sees any mistakes, or has any suggestions, I would be very happy to hear them.
Blocks:
85 CPU: CPU-370 1.5mm Midplate (2 ID13) http://bit.ly/ogKEBc
9 CPU Adapter: Adapter, Intel Socket 2011 (not yet released)
140-210 RAM: RAM-33 (Single DDR/DDR2/DDR3/SD) (8-12 ID10) http://bit.ly/papFtz
55 Hard Drive: HD-60 (HDx2) (2 ID10) http://bit.ly/pkp024
45 Northbridge: CHC-125 (MB) (2 ID10) http://bit.ly/qI10w4
45 Southbridge: CHC-125(MB) (2 ID10) http://bit.ly/qI10w4
0 Graphics Card: Hydrocopper 590 (4 ID13)
Pumps:
70 ID 10: Pump, PMP-400 http://bit.ly/oGu0BF
35 Speed Controller: CTR-SPD10 12v Pump Speed Controller http://bit.ly/pvnzHV
33 Reservoir Base: Pump Nozzle & Reservoir Base for PMP-400 (60mm OD) (2 10) http://bit.ly/odJA3O
77 ID 13: Pump, PMP-450
35 Speed Controller: CTR-SPD24 24v Pump Speed Controller http://bit.ly/nUAQk9
45 Reservoir Base: Pump Nozzle & Reservoir Base for PMP-450 (2 13) (60mm OD) http://bit.ly/plehZg
Reservoirs:
20x2 Bodies: Reservoir Body, 60x240mm, (471x2ml) http://bit.ly/p1Rsil
10x2 Brackets: Reservoir Bracket, 140mm http://bit.ly/ngr2UF
10x2 Tops: Reservoir Top with Fill Port (60mm OD) http://bit.ly/pO3Mxi
Radiators:
50 ID 10: Radiator 1x140mm 30-FPI Copper (2 10) http://bit.ly/pcokov
60 ID 13: Radiator 3x120mm 30-FPI Copper (2 13) http://bit.ly/pxNOmY
Coolant:
15x2 1400ml: Liquid Coolant Bottle, High Performance, 700ml (Blue) http://bit.ly/nRD1B1
Tubing:
1.3/ft ID 10: List of colors page http://bit.ly/qpCJeu
1.8/ft ID 13: List of colors page http://bit.ly/roG2VN
Nozzles:
9x18-22 ID 10: Nozzle Pair, Compression id 10 (18-22 ID10) http://bit.ly/psj0T2
9.5x10 ID 13: Nozzle Pair, Compression id 13 (10 ID13) http://bit.ly/nZi4D4
Final Price
85+9+140+55+45+45+70+35+33+77+35+45+40+20+20+50+60+30+162+95= 1151
85+9+210+55+45+45+70+35+33+77+35+45+40+20+20+50+60+30+198+95= 1257
Blocks:
Pumps:
Reservoirs:
Radiators:
Coolant:
Tubing:
Nozzles:
Final Price
