Hey everyone, curious your opinions on the score. Whats the biggest bang for my buck to upgrade? I'm on a slim budget.
AMD Radeon HD 6850 video card 3DMark Vantage benchmark test score
Name
Description
Processor
Intel Pentium Dual-Core E5200
Processor clock 2500 MHz
Graphics Card
AMD Radeon HD 6850
Memory
1024 MB
Core clock
850 MHz
Memory clock
1055 MHz
Operating system
32-bit Windows 7 (6.1.7601)
Motherboard
Gigabyte Technology Co., Ltd. G31M-S2L
Memory
4096 MB
Module 1
2048 MB G.Skill 7 @ 400 MHz
Module 2
Hard drive model
250GB ST3250410AS ATA Device
3DMark Score
8843 3DMarks
Graphics Score
12896
CPU Score
4551
Jane Nash
37.85 FPS
New Calico
37.7 FPS
AI Test
591 operations/s
Physics Test
6 operations/s
Settings
Default settings used
Yes
Preset
Performance
Width
1280
Height
1024
MSAA
Texture Filtering
Optimal
Anisotropy
Texture Quality
Performance
Shader Quality
Performance
Shadow Shader Quality
Performance
Shadow Resolution Quality
Performance
Post Processing Scale
1:2
PPU Disabled
true
PPU Used
false
Disable Bloom
false
Disable Streaks
false
Disable Anamorphic Flare
false
Disable Lens Flare
false
Disable Lenticular Halo
false
Disable Motion Blur
false
Disable DOF
false
Disable Fog
false
Disable Color Noise
false
Flush On Low FPS
false
Fixed Framerate
false
GPU Count
Name
Description
Processor
Graphics Card
AMD Radeon HD 6850
Memory
1024 MB
Core clock
850 MHz
Memory clock
1055 MHz
Operating system
Motherboard
Memory
4096 MB
Module 1
Module 2
Hard drive model
3DMark Score
8843 3DMarks
Graphics Score
12896
CPU Score
4551
Jane Nash
37.85 FPS
New Calico
37.7 FPS
AI Test
591 operations/s
Physics Test
6 operations/s
Settings
Yes
Preset
Performance
Width
1280
Height
1024
MSAA
Texture Filtering
Optimal
Anisotropy
Texture Quality
Performance
Shader Quality
Performance
Performance
Performance
1:2
PPU Disabled
true
PPU Used
false
Disable Bloom
false
Disable Streaks
false
false
Disable Lens Flare
false
false
Disable Motion Blur
false
Disable DOF
false
Disable Fog
false
Disable Color Noise
false
Flush On Low FPS
false
Fixed Framerate
false
GPU Count
