Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Antec 1200 case POWER button not working
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Antec 1200 case POWER button not working
Hello all, I have an Antec 1200 case but the POWER button at the front of the case doesn't work.
The RESET button works, but not the ON/OFF power button.
So when I turn it on, I have to use the onboard power button my my p6t deluxe v2 mobo.
It gets annoying having to open the case up all the time to turn it on... and I will probably be selling the computer in the near future so I need the case button fixed.
Is there an easy way to do this???
OH.. and YES, the jumpers for the button are connected properly to the mobo..
So does anyone have any information they could share with me about fixing this small but annoying problem???
I'd appreciate the help greatly!!
Sponsored Links
Assuming you can't get at the button and repair or re-place it (it is a VERY simple momentary-contact switch), you can use the Reset button instead. It is the same type of switch. So just take the little connector from the Reset button that plugs onto 2 pins on the mobo connector for the front panel, and move it to the pair of pins for the on/off switch. You will have a good on/off switch with the wrong label on the front, but no Reset switch.
Reply to Paperdoc
ahhh...good point about changing the reset button to the on/off...
I will get on that tomorrow. So thankyou...
Still, I'm going to have to get the original on/off button fixed. But... the workaround will work for now!
Cheers.
Reply to binny
Contact Antec. You should be able to get a replacement from there.
Reply to jsc
That workaround will get you through the tough times for the time being, thanks to Paperdoc for posting it!
The best thing to do is to contact our Customer Support department. Link: http://www.antec.com/Believe_it/in [...] ort_online
If it's still under warranty we should be able to help you out in getting it fixed/replaced.
Reply to Antec_Rep
Antec is pretty good about having every possible replacement part even for out of warranty chassis if they are still kicking around. I need to order a couple things come to think of it lol
Reply to roofus
There are 729 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
