Power Saving Mode
Forum Graphic & Displays : Graphics Cards - Power Saving Mode
Hi,
Sometimes my computer decides to go into "Power Saving Mode" this is what's displayed on my monitor and then I cannot wake it up to use the computer again. You can hit any key on keyboard and the computer will not display anything until you physically power off the computer an power it back on.
I have replaced the video card thinking that the video card had been faulty nut the problem still exists.
Is there a software tool that I can install to try and pinpoint the problem as it is becoming frustrating.
If anyone has any other suggestions on how to find out what the problem is, please say.
Sponsored Links
FallenSniper wrote :
You could disable power saving mode.
How do I do that? Is that a property of the video card or monitor? Or something else?
Reply to GeekMe
Right click your desktop ---> properties ---> Screensaver ---> Power. Then change all the drop down menus to never.
That's how you do it within windows at least. I suppose it's possible its a power saving option within your bios...but try that first and see if it works.
Reply to FallenSniper
I have seen where there are power saving modes in the monitor as well. If this happens again, try unplugging the power to the monitor and plugging it back in. Also, maybe check for power saving settings on the monitor itself.
Reply to johnmoney
Folks,
This happens when I'm working away on the pc and all of a sudden the screen goes blank but the pc is still running. It also happens on startup as well. I sut down the pc come back the next day and when I power it on i get no display on the monitor but the pc is still going through it's boot process.
Any thoughts and ideas are welcomed.
Reply to GeekMe
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Power Saving Mode
There are 1013 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
