One drop on a fan bearing is quite sufficient and not too much so don't worry about excess oil spraying out. However, I agree with jsc. The bearings will dry out and start having problems again, and there's a limit how long you can keep on adding oil. Prepare to replace, and this time go ball bearings if you plan to keep those fans.
Yea I am well aware that ball bearings will be better and I will get those next time.
Last question:
The other fan always spinned at ridiculous speeds(RPM).Airflow was also amazing with it.
But when I removed the sticker on it I found that there was some OIL already leaked there.
Here I need your suggestion.
In the space around the end f the bearing/shaft and covered by the sticker there always will be a small amount of oil - enough to make it look slightly damp. If there is a lot of oil there, that would be weird. So unless there's a lot already, adding one drop is fine.
