I have a i7 920 processor on a ASUS P6T SE board. The board has 6 memory slots. I currently have 3 GB (3 x 1 GB) of ram. The speed is DDR3 1333 (PC3 10666) with a case latency of 7 and a voltage of 1.5v - 1.6v.
I have 3.5gig and the only time it becomes an issue is when i start doing a lot of stuff in photoshop and premier at the same time. I actually had to try and bog it down.
Unless you are using 64 bit CS4 each program cannot use more than 2 GB of RAM. For web developing, dreamweaver wont appreciate the extra ram, but if you work with flash, fireworks, or photoshop a bunch you might notice a difference, but it likely wont be much.
