Tom's Hardware > Forum > CPU & Components > Sound Cards > Realtek HD Audio and Surround Sound issues
Forum CPU & Components : Sound Cards - Realtek HD Audio and Surround Sound issues
Apologies if this is going over old ground but I've spent literally hours looking through various forums trying to solve this problem and have been unable to succeed.
I have an HP MediaCenter PC running Windows 7 Home Premium. It has Realtek HD Audio and I have our Yamaha RX-V350 AV receiver connected to the coaxial digial output from the Realtek soundcard. The receiver is DTS and Dolby Pro Logic II compatible.
I can play 5.1 DVDs and surround sound works fine. No problem at all.
However, I now have an MP4 file which MediaInfo, the utility provided with KLite, indicates contains a 6 channel AAC audio. However, no matter what I do I can't convince Windows Media Player 11 or the MediaCenter software to play in 5.1 sound. I get standard 2 channel.
Realtek digital output is set as the default playback device.
In Control Panel, Supported Formats, clicking "test" for both DTS Audio and Dolby Digital correctly results in surround sound being output to the speakers. My receiver actually displays when 5.1 is in use too. DVDs work fine, as indicated above.
I just can't get these MP4 files, encoded in 5.1, to play as 5.1.
I even downloaded some test files from a website encoded in 5.1 in other formats and they too wouldn't play in 5.1, just standard 2 channel.
Is this just a "feature" of the Realtek card or is there something I can do. I've tried KLite codecs and from what limited knowledge I have, couldn't rectify the problem either.
Any assistance, gratefully received.
F
Sponsored Links
Isn't is possible that the MP4 vids you've downloaded simply don't have the audio tracks to populate all of the channels?
------------------------------ Desktop | E7300 | P5KPL-AM | 2GB DDR2 667MHz | NVIDIA 9500 GT | ST3320613AS | w2228h
XPS M1330 | T8300 | Dell 0U8042 | 2GB DDR2 800MHz | NVIDIA 8400M GS | WD2500BEVS-75US | 1280 x 800
Reply to r_manic
The MP4s in question contain 6 audio channels. I have the same issue with purchased and rented movies on iTunes.
Reply to ffcphone
- 0 +
i have the same problem when using klite and its ffdraw filters. i had to use the AC3filer to get surround from any source when i used Realtek. What filter are you using?
Reply to xupaguy
I've tried it just with the default Windows 7 setup and also with the klite full codec pack installed. However, I do not see any icons on the system tray when running video in Win7.
Reply to ffcphone
There are 1267 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
