OK, so i finally decided to build my own gaming pc. Like everybody else I want something that can kick Crysis's ass XD. But I also work with a lot of 3d graphics and other heavy duty programs. Sometimes I will need 3Ds Max, Photoshop CS4, Sony Vegas, and probably other things all open at once (that is my reason for the quad core) My only true main concerns about this build are the - cpu, motherboard, and graphics card)
My budget is also strictly around $1000
I've looked all over the net and this is what i came up with this.........
Hmmm... seems solid enough but i'd recommend a core i7 instead of your current choice of cpu. i7 would be more powerful and similarily priced.this means getting a new mobo, but there are some great x58 mobos out there which arent too expensive. this will future proof your system a good bit, also most x58s suppore sli or xfire, which gives you more upgrade choices.
not to mention i7s ocing potential...
Link to an i7 setup that would keep him under budget if you could, im curious to see it(i suck at finding the budget i7 boards)
Why pay 140 for a PSU when the Corsair 750TX is just as strong and only 120 with a 20 MIR, or he can get a TP-750 combo'd with his case for significantly less
http://www.newegg.com/Product/Comb [...] mbo.232529
the best deal i can find is still 100$ more than his current one, but i still think it's the best bang for buck option. its open box, but that usually just means it was on display at an exhibition or something, so nothing to worry about. http://www.newegg.com/Product/Prod [...] 813131386R
Message edited by unholygregor on 08-22-2009 at 08:38:51 PM
I don't think an i7 is appropriate for his budget if he plans on gaming. He would have to increase his budget by roughly $120 dollars to get an i7. On the other hand, FoxFlames, you may consider this budget increase worthwhile. The i7 920 is truly superb. With a descent air cooler, you could overclock to 4 ghz without voltage increase (if you get a D0 stepping model). Otherwise, I recommend you get a AMD Phenom II model. It is faster and cheaper than an Quad core Q9650. It also had more upgrade potential, since the lga 775 socket is basically dead (the core 2 socket). Either way you go, you won't be disappointed by the performance. Good luck!
