APPROXIMATE PURCHASE DATE: Like it to be within a week, even this weekend.
BUDGET RANGE: US $500
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, movies, internet streaming movies, surfing, productivity
PARTS NOT REQUIRED: Technically, I don't need a monitor, but I've included one because it's so cheap. No keyboard, speakers, DVD drives, case (using Antec P180 quiet case), OS (may upgrade in future to Win7. Using XP now and yes I know about memory cap in XP), power supply. Currently using a Antec Phantom 500 500W ATX12V and love it. I picked some parts with this in mind. It *should* be sufficient for my build.
PREFERRED WEBSITE(S) FOR PARTS: newegg.com unless a really compelling reason is suggested for another. I've been buying from them for years.
PARTS PREFERENCES: Would like to stay with Phenom AMD CPU, XFX Nvidia graphics, Gigabyte MB, WD Green drives. 2 cores on CPU is as expensive as I'm willing to go.
OVERCLOCKING: Yes SLI OR CROSSFIRE: Absolutely No
MONITOR RESOLUTION: 1920 x 1080 or there about. (monitor and graphics both support)
ADDITIONAL COMMENTS: Looking to make a quieter more energy efficient machine. I know I've really blown it with a couple of the parts I've picked, though. If you can suggest improvements, great.
I had parts picked out for a sub 500 machine, then saw a 24" monitor cheap, and did a little reading about them and picked the one I have below. My mouse is dying, so I threw in a wired gaming mouse, too. As of tonight, the parts without shipping are 751.92. If I went over 800 bucks, I'd freak. It's already 250 more than I really wanted to spend. That monitor is really got me happy, though, and even if I do NOT buy anything else, I'll be buying a monitor.
Upgrading from a machine that's almost four years old (December 2005. Still have the newegg receipt), and I still play most games reasonably well (Oblivion, Fallout 3, any MMO I've tried). Still, this will be a major upgrade for me even using budget parts. The parts I picked have lasted VERY well over this time. I'm hoping for at least 3 years out of what I get now.
Any advice on going cheaper, better memory, better AMD CPU, better graphics (cheaper if possible), or really any better, but similarly priced parts would be appreciated. These parts should all be compatible.
In the past, I had extensive knowledge building machines and have built many, working for a small company, then doing it myself, but I've been out of it for a few years now. If I made a mistake with any of this, please point it out.
May I ask why you want a 750 GB green drive, for a gaming PC, it's better to go with a Black or a Samsung Spinpoint? The number of platters and "green" part make it quite slow. I would also get a different GPU, how about ATI? You've really limited the number of possible suggestions with your list of preferred parts, making it somewhat difficult to make recommendations...
I'm a Linux user as well. ATI decided to not support older hardware with their latest drivers on the latest Ubuntu, and I would rather not buy another ATI video card at this time. Nvidia's are supported just fine, though.
The Green drives are purchased for power consumption in mind, as well as dB. They're better than what I have. I realize this Black drives are faster, but noisier, and more hungry. If you can recommend other low power, low noise drives, great!
I'm not really interested in a blazing system. Everything I have listed is a major upgrade from what I have, and I already play everything I want to. All I'm looking for is improvement on a tight budget. If you can tighten the budget, and improve performance, give me the suggestion even if they contradict my preferred parts.
That said, I intentionally limited things so responses would be faster. The broader my desires, the more items there will be to fill them, and the harder it will be to narrow my decision. I'm already pretty set in my ways and who I like to support from having worked with computers since the mid 80s (yes, I know ATI is owned by AMD these days). I'd almost be willing to switch to an Intel, but I haven't owned one in over a decade. It would feel funny.
Anyway, if you can't help, thanks for reading anyway. If you can help out, it's much appreciated.
No offence dude but JUST having one green part in your computer is not going to make much of a difference than one without.
I use linux..and dbs...and microsoft, so I know where you're coming from. But still, just having a big psu will cause your pc to suck out more juice than it actually uses.
