Alrighty im looking to build my first watercooling set up in my system. yes i have been researching the hell out of it for the past few months. im looking to do a loop to cool an overclocked I7 920, chipset, and 3x GTX 470's.
my CPU block im looking at is a: Swiftech Apogee XT
the Rads im looking at are: XSPC 4x120, and 2x120
the chipset block is a: EK EVGA X58 SLI LE block
the GPU blocks are: Swiftech MCW82 + the full cover heatsinks for the GTX 470's
All BitsPower fittings
the pump/res im looking at is the: XSPC X2O 750
the tubing is PrimoChill PrimoFlex 1/2ID 3/4OD Tubing
and coolant is PrimoChill Pure Extreme Coolant
the loop is going to be:
pump>cpu>chipset>240 rad>470>470>470>480 rad>back to pump
now i will have the 90degree fittings on the swiftech gpu blocks.. ive heard mixed things about the 90's causing extreme flow restriction and stuff but idk thats why im here!
it will all be installed in a Corsair 600T Case with the 480 rad mounted off the back.
now my questions are...
is that pump going to have enough power to push through that loop effectively as a single loop?
are my rad's going to provide enough cooling for all the heat ill be creating?
is there any critical components i have overlooked?
are there any just major flaws that are going to create chaos for me down the line?
ANY and ALL help would be greatly appreciated!
thanks everyone!
thanks everyone!
