So after an unfortunate water cooling accident involving my old 680i board I have rebuilt my computer with an upgraded p45 board by DFI.
The last thing I needed was a graphics card, and I have run my computer for extended periods of time without the GPU just to test the water cooling system for leaks, so it appeared to be stable.
Today I went to best buy (temporary fix if you know what I mean) and bought a radeon HD 4890 PCIex16 graphics card. I plugged it into the motherboard, attached the 2 12v connectors from my PSU and turned on the system. To my excitement, it worked and I entered the BIOS to check settings and temperatures. Upon entering the "PC HEALTH" page to check volts and temps my PSU exploded with a loud sound and a lot of fireworks, followed shortly by a nasty burning electronics smell.
My question is, what could have caused my PSU to do this? It seems like it's related to the graphics card but I don't understand what about that would cause it to go boom.
Thanks for any help,
I'm going crazy with this fix, first my mobo is dead, then my GPU turns out to be dead, get a new one, PSU explodes 5 minutes into use... this is ridiculous
Well, you did mention a "water cooling accident." Had water gotten into the PSU? Are you certain everything else was dried off? Your rig should not have stressed an 850W PSU.
Jonny gave this one a 7.5. When you replace it, a 650W model from Antec, Corsair, Seasonic, or PC Power & Cooling would be good choices. That's for your current rig; if you planned to add another HD4890 later, get 750W.
The order of events led me to believe I might have done something to cause that. It wouldn't have to do with something touching something it shouldn't on my motherboard or video card would it?
Message edited by jtt283 on 11-15-2009 at 04:13:09 PM
It had been several weeks since the water leaked out of the south bridge block and onto the motherboard, and I had run the PSU for many hours beforehand so I doubt there was any water on the PSU. I checked everything for leaks after the PSU died and found nothing.
Is it weird that the PSU died so dramatically or is that fairly normal?
