ASrock X58 Extreme Overclock Help
  • CPUs
  • Overclocking
  • Heatsinks
  • Intel
  • ASrock
October 25, 2011 1:03:32 AM
Motherboard: ASrock X58 Extreme
CPU: Intel I7 920
Heatsink: Stock Intel Heatsink
My question basically is this. I'm looking to overclock my CPU (Not a ton, but just enough) to get it around 3.2 Ghz.
A) Is this possible with the standard Intel Heatsink?
B) Is it safe?
C) If A and B are a yes, what can I do to achieve this?
Hope this is enough information with the following picture, and ty in advance!
More about : asrock x58 extreme overclock
a b à CPUs
a b K Overclocking
October 25, 2011 3:16:34 AM
ah trust me when i say this, 1 heat sync dosent make the overclock better than the other, 1 is probaly better but
A)yes
B)if you monitor your temps closely, your TCASE is 67C so try to stay below that
C)you can try using intels turbo boost
m
l
a b à CPUs
October 25, 2011 3:33:28 AM
Sure, you can, but really watch those temps. I see you have a D0 920. It deserves a nice cooler, so imo get one and OC it to 4ghz :)
m
l
October 25, 2011 11:41:21 AM
I will most certainly give that a shot guys thank you very much!!! :)
m
l
October 25, 2011 11:57:06 AM
So far got a stable 3197 Mhz without going above 52C!!!! Ty guys :)
m
l
