Big HDTV problem
Forum Graphic & Displays : TV/Video Cards - Big HDTV problem
Hello tom's users .Recently i've receive a gift from a relative,theyr used HDTV 32 inch Technika .It worked very well for them,with no problems.The thing is when i started using it the display started .....crying...its weird to describe it.There are 3 blur colored lines in the middle of the screen,intrerupted,some with mixed colored pixels ,red and blue. From what i've been able to read on the web,it seems they are stuck pixels,but i didn't read of a case so bad .There are columns of them .If i let the TV off for a couple of hours,they start to fade ,but after usage they get pronounced again.They are concentrated in the same area,and between these lines smaller lines start apearing after usage.I've tried the pixel fixing software on the net,non of them worked.Warranty i don't have.
If anybody at least can shed some light on the issue with the damn thing.
Thank you
Sponsored Links
Here are 2 photos i managed to take on a white background if it helps
http://forum.computergames.ro/attachment.php?attachmentid=521561&d=1252430152
http://forum.computergames.ro/attachment.php?attachmentid=521562&d=1252430152
Reply to Shakabutt
Could have been damaged during transport.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
Where? on the screen there isn't a crack or any sign of abuse.In 2 days since i got it,it started realy slow,now its becoming more proeminent after use,its like a large patch on thee middle.
Reply to Shakabutt
Blue lines sprinkeled with dark blue and red pixels
I swear this is really anoying
Reply to Shakabutt
Why don't you buy your own hardware and quit crying...
Reply to marcellis22
Hey chill friend,i only wanted to know if any of you had any ideea,i didn't cry or twisted anybody's shoulder.
Reply to Shakabutt
- 0 +
You haven't posted enough info about the set, model, type LCD or CRT.
------------------------------ ASUS Striker II Extreme , C2D Q9450 OC 3.4, 8 Gig Memory, EVGA 8800GTX Triple SLI, Thermaltake 1000W PSU, Thermaltake Armor + Case, Acer 24" LCD, Water Cooled, 12 Foot DVI Cable, Vista 64 Bit SP2
Reply to baddad
Its an 32 Inch Technika LCD ,beyond that,i really don't know
Reply to Shakabutt
Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Big HDTV problem
There are 1353 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
