Hello to all, I am hoping someone here might know what my problem is and what the solution is.
I have an HP m9450f which comes with an ASUS IPIBL-LB motherboard and I have been having issues lately with the CPU and Case fans (controlled of motherboard with multi-wire fans) running at full speed on cold start up and during idle period. I have SpeedFan 4.40 running (To Monitor Only) the fan speeds and I can see them speeding up to 4700 and 2600 RPM, here is a video I made of what the fans are doing, during IDLE
=http://www.youtube.com/watch?v=h7fWb6A9Q9U
Also I have re-installed Windows 7 Home Premium 64Bit (Vista 64Bit was pre-installed on system) and it was doing it on Vista as well. I have upgraded the PSU to and OCZ ModXStream Pro 700, so I know my PSU was not the cause, I have updated the BIOS to the latest version 5.32 SP40908.exe according to HP.
=http://h10025.www1.hp.com/ewfrf/wc...&dlc=en&cc=ca&lang=en&os=2100&product=3805274
I have found another system that runs the same motherboard and has a bios update to fix the issue I am asking about, but everyone says DO NOT USE IT.
=http://h10025.www1.hp.com/ewfrf/wc...&dlc=en&cc=ca&product=3876397&os=2100&lang=en
I think it is an error on HP's part and not posting it on my model systems updated bios list b/c the requirements state I have to have the IPIBL-LB motherboard, that system had the 5.32 update like mine SP40908.exe so what does everyone else think???
