Yes No
Ads
Tom's Hardware > Forum > Overclocking > Water Cooling > Which direction should air travel from cpu water cooler
Forum Overclocking : Water Cooling Which direction should air travel from cpu water cooler
Hi there i have just bought a pre built system from overclokers.co.uk i7 920.... its has a OcUK H2 Flo Extreme Cooler, which has only come with one fan? first i am thinking this needs two fans one either side of the radiator? and i asume air flowing from inside the case out? the problem is the cpu is hitting 90c idle so i know its not working properly! someone help me!
Reply to Putts
90c idle is on the verge of destroying the chip you know...
Reply to chilypepper
It sounds like you have air keeping your pump from flowing. Tilt and tip your case with it running to see if it will dislodge and bring your temps down. 90C at idle is very bad.
------------------------------ Watercooling Info:
Tom's Hardware Watercooling Sticky
Build Log | Project: Askew
Stuff 4 Sale
Reply to rubix_1011
The typical setup has the fan set as an exhaust, but that is the least of your problems. Even with the fan not running you shouldn't be seeing those temps. Either the contact base is not seated properly or your pump isn't running. Check your connections to make sure the pump is plugged in and working. I'm not familiar with the cooler, does it have software to monitor it?
Reply to ciarlatano
Putts- can you post a link to the cooler? You may want to do a couple tests and if they don't result in any change...RMA the system. 90C idle isn't good on a chip.
Stuff 4 Sale
Reply to rubix_1011
- 0 +
Wow thanks for your quick replys! Turns out the pump wasent working....... they are sending me another tmw! hopefully just in time for bf3 uk release in uk friday!
This is the cooler https://www.overclockers.co.uk/show [...] =HS-006-CS
they had used it as their own brand. Does anyone have this cooler? The system shut down wile i was installing windows 7, this is when i checked the bios tempuatures and saw the temp hitting 90c, i rekon it was only at this temp for a matter of seconds before shut down which happend maybe 10 times wile i made adjustments to the cooler? do you think there will be lasting damage to the cpu?
Reply to Putts
The CPU and motherboard are designed to shut down when they reach thermal threshold. You might ask them if they will just RMA the entire system since the cooler was deemed to be broken. No sense in getting a brand new system and only have them replace a single part...maybe make them replace the entire system. That being said, I doubt there is any permanent damage, but I personally would want them to make it 100% right by sending you a replacement.
Stuff 4 Sale
Reply to rubix_1011
There are 1497 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Does a computer NEED ram?
By Motopsychojdn, 2 hours ago:
A Pc will not function without ram, simple as, can you post the model/make of your Pc and...
Best offers
Top experts
