Tom's Hardware > Forum > CPU & Components > CPUs > Question about CPU speed
Forum CPU & Components : CPUs - Question about CPU speed
Hello,
CPU-Z is reporting:
Name: Intel Core 2 Duo E8200
Code Name: Wolfdale
Tech 45nm Core Volt 1.120
Intel Core 2 Duo CPU E8200 @ 2.66Ghz
Core Speed 1995.0 Mhz
Multiplier X 6.0
Bus Speed 332.5 Mhz
Rated FSB 1330.0 Mhz
Can you help me understand why the speed is 1995.0 Mhz instead of 2.66Ghz?
My Motherboard says it supports 1333 bus, but is the CPU going at its potential?
Sponsored Links
probably intel speed step which lowers clock and voltage to reduce power and heat when idle
Reply to mindless728
Enhanced Intel Speedstep Technology. It's a feature that reduced voltages and clock speeds to conserve power. When in idle states or using very little CPU power, EIST will kick in and bring the voltages and clocks down.
When your PC needs more raw power, your voltages and clock speeds will go back to default.
Reply to TheViper
There are 765 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
