Yes No
Ads
Speed up my pc
Forum Windows XP : General Discussion Speed up my pc
Hello, This is Deepak,
I am using Windows XP (SP 2) as OS, when i am using virtual machine
the pc went slow down, (it takes almost 10 minutes just to open my computer window )
please suggest any ideas to speed up the system when i opened the vmware
(In vmware i am using two os's- windows server 2008 and windows 7 as server and client)
my system configuration is
1.5 GB of RAM,
Intel processor Dual core 3.00 GHZ,
160 GB of Hard Disk
Reply to deepak4network
What is your RAM usage like? Maybe you need more RAM. I have 6GB in my main Windows 7 machine, and I can run several virtual machines at once using VirtualBox.
Reply to PhilFrisbie
i am using 1. 5GB RAM for main windows xp. if i increase the RAM to 2GB can i speed up my computer?
Increase your RAM and scan your C drive and delete virus.
------------------------------ World's largest online casino directory to play online gambling, casino gambling, online bonus, best internet casino and many more.
Reply to casinoplayer
no problem with virus, i have avast antivirus automatically updates daily. so no problem with virus.
i think the first option that increasing my RAM speed can be some use....?
Yes, increasing your RAM will help. How much are you allocating to the virtual machine?
I run XP (VPC) on a similar spec machine to yours (windows 7 pro) but I have 4 gb (3.12gb) RAM (32 bit).
I'm not an expert, but suspect there is no way I could do it with 1.5gb.
Maybe someone with more knowledge can advise how to look at your RAM usage when running a virtual machine and if it's possible to allocate your resources better.
Reply to davidjuk
i am using 512 MB of RAM for windows server 2008(for windows server 2008 minimum requirement of RAM is 512 MB).
And for windows 7 i am using 512 MB of RAM.
I am afraid that if you want to speed up your computer manually by others, you should pay for it .But i know a website which can do a free manually detection, i have tested, www.anylives.com , you can have a try. As to the speed up articles, the website has some, and the registry is better. If you want to speed up by yourself, you can try it. Or maybe you should update your hardware,such as the memory and clean system garage often,uninstalled the programs you don't use usually
Reply to steave
You need more RAM in your computer. You are only leaving XP with 512MB of RAM when you run both the VMs. You really need to upgrade to 3 or 4 MB of RAM so each can have at least 1GB.
Thank you, may be upgrading my RAM is the best option.
Thank you for suggestions.
Yea RAM is massive, but dont forget about your registry, and your catches. As well as just simply cleaning your fans of dust.. It all makes a difference. I think I have posted this before, but the most non-spammy program for the registry is PC tuneup maestro ( http://www.compuclever.com/products/pc-tuneup-maestro/ ) or CC cleaner. That ones works too..
Goodluck!
Reply to b-hooster
Tom's Hardware > Forum > Windows XP > General Discussion > Speed up my pc
There are 1542 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Microsoft Updates - In Triplicate !
By Hawkeye22, 1 day ago:
They won't show up in add/remove programs because they were superceded by a different...
Best offers
Top experts
