G.Skill Ripjawz 2x4 2GB @ 1600 mhz
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231277
1. I was wondering if under-clocking and lowering the latency of my memory was more effective than overclocking? (I think my mobo info said it's max was RAM speed1866+ (why a plus sign?)
2. Would this put much of a strain on my PSU? I've just received my other 4gb of RAM + my Noctua NH-D14 CPU heatsink. Not only did I want to overclock my RAM, but also my CPU and GPU (1015mhz goal in mind) . I think it's getting pretty close to maxing it out. Not sure, I've never overclocked before.
3. What should i use for a RAM stability test, and how long to run the test(s) before it's considered stable?
What I have :
Gigabyte 890-FXA-UD5 AMD motherboard
AMD 1100T x6 Thuban (right NOW @ 3.4ghz x6 cores) **but just recieved my Noctua NH-D14 today, and want to try to get it to 4ghz or higher**
XFX -XXX edition 650 watt PSU
MSI 6970 Lightning @ 980mhz
8GB of G.Skill Ripjawz @ 1600mhz RAM
Cooler Master HAF-932
