SYSTEM STARTUP PROBLEM
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - SYSTEM STARTUP PROBLEM
hellooooo
i m getting probs in my pc while i m switching on the pc the msg show
[A DISK READ ERROR OCCURED PRESS CTRL+ALT+DEL TO RESTART]
press these key reboot the system and again this msg is showing
can anyone advice me wat to do ........
THANX....
regards:
Pritam
Sponsored Links
Disk read errors are usually associated with corrupt files or a HDD that is dieing. I would suggest copying your data off and then trying a clean install - if the problem persists then its more than likely your HDD failing.
Reply to ulysses35
my system is not booting so hw can i save my all data frnd ulysses35.....??
Reply to pritamsingh98
Three possibilities. You can pull the drive out and connect it to another computer. Or you can install another drive, put an OS on it, make it bootable, and use it to backup the data from the original disk.
Or you can make a BartPE disk. (Google it.)
Reply to jsc
You could try running Scandisk from either a USB Dos or a bootable floppy,,you might get lucky,or as mentioned buy a new hdd and copy stuff to it after installation..
For future consideration,,get a hold of Norton Ghost and Ghost your primary partition regularly then when you have snafus you will have a ghost that can restore your system,primary partition in a few minutes... :)
------------------------------ When you obsess on your enemy,,
You become The Enemy...
Reply to dokk2
is there a floppy disk in the computer? remove it
Reply to Anonymous1
Try changing the cable for your hard drive.
Message edited by dunklegend on 11-17-2009 at 07:36:49 PM
------------------------------ Never argue with a fool, people might not know the difference
Reply to dunklegend
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > SYSTEM STARTUP PROBLEM
There are 1282 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
