Tom's Hardware > Forum > Home Theatre > Tivo > Problem with TTG and new pc
Forum Home Theatre : Tivo - Problem with TTG and new pc
Archived from groups: alt.video.ptv.tivo (More info?)
Hi all,
I just built a new pc, and am having trouble with TTG transfers (tivo
to pc) stalling after a few minutes. If I try the transfer directly
via my browser, the transfer stalls after exactly 17.2MB.
new pc:
DFI Lanparty Nforce 3 250 mobo
Athlon64 3000
1GB corsair RAM
New install of WinXP Pro w/ SP2
Everything with TTG worked fine with my old pc. And if I run Tivo
Desktop on my laptop, everything works fine. I just don't have a new
enough laptop to use for TTG, instead just running it on the laptop
and setting my save folder to a mapped drive on my main pc.
Any ideas on any settings on the pc/mobo that may be causing trouble
here?
TIA,
Martin O'B
Sponsored Links
Sounds more like a memory address problem than a mobo problem. Have
you been having problems with any other programs? When something is
downloaded it usually keeps it in memory then dumps it to the hard
drive. you might see about bumping up your cashe in your o s im
assuming your using windows xp?
On Mon, 25 Apr 2005 13:33:19 -0400, Martin O'Brien
<usenet@martinobrien.com> wrote:
>Hi all,
>new pc:
>Athlon64 3000
>1GB corsair RAM
>here?
>TIA,
>Martin O'B
Reply to Anonymous
In article <tkkg71tu8o5mfleenlsu018vsmjkopgnge@4ax.com>, dont@know.com
> >Hi all,
Check the Energy Saving settings for the computer and the ethernet card,
maybe TCP is being turned off due to no keypresses???
> >new pc:
> >Athlon64 3000
> >1GB corsair RAM
> >here?
> >TIA,
> >Martin O'B
Reply to Anonymous
There are 1214 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
