Ok so here is an odd question.. and I know HOW to do it, I'm just exactly sure what i exactly need. So here it goes. I have a Thermaltake Element S case. I love this thing, its awesome, easy to assemble, good cable management, EVERYTHING is awesome. Except the insanely bright HD and Power LED on the top. They are so bring in fact, that at night when it is in standby the power LED blinks so bright that it lights up an entire corner of my room. I can see it blink with my eyelids shut, it reflects off the ceiling.
So I propose to make some sort of inline resistor that I can just plug into the power LED and HD LED plugs that connect to my motherboard. I figure i could find a plug similar and just solder a resistor inline and shrink tube it. Now my question is this, are there any ill effects to doing this? Is it bad for my motherboard to have a higher resistance on those outputs? Also, what Ohm resisters should I use and what type of resistor would work best? I am handy with a soldering iron, and understand basic electronics, but when it comes to exact resistances and type of resistors, I'd like to look to someone that knows a little more.
Any ideas? Right now I have a little square of folded paper taped over the LED... not so attractive.
