Tom's Hardware > Forum > Graphic & Displays > ATI > PowerColor 4870 Power Consumption
Hi guys, i bought a PowerColor 4870 1 GB yesterday. I wanted to know how can i reduce power consumption of my graphic card?
Most of the times i'm not using high graphic games and my system is in idle status but as i know the graphic card uses about 140 watt while it's idle :ouch:
Is there any program for reducing power consumption of graphic cards?
Also i wanted to ask if i reduce graphic card's memory clock & GPU clock, does it damage the graphic card? Could it be a way for reducing power consumption?
Thank you for answering my questions
Sponsored Links
o ok im not sure about asus i just got myself an gigabyte and it came with a programe that saved watts from the cpu called easy saver it takes it from 3.2ghz to 800mhz
did you check the cd?
it also dropped my cpu heat 10 decress :)
Message edited by sirkillalot on 09-15-2009 at 03:55:59 PM
Reply to sirkillalot
Yes, ASUS has the same thing but...
It doesn't work for my graphic card :(
Check this out:
http://www.tomshardware.com/forum/263358-30-engine
Reply to Zap_Warrior
Any one? :(
What about changing the frequencies?
Heeeeeeey guys...
Is there any program to gain control of power consumption of the graphic card?
i dont think so cause if you start messing with that all sorts of *** can happen
but if u lower a cpu it just doesnt run as fast
There are 740 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
