OVERCLOCKING CPU? HELP
The processor I have is a 1055t AMD With stock CPU FAN. I Haven't seen it get above 45C playing Battlefield 3 All high settings, 1 on setting on Ultra, and 1920x1080 resolution. I get 40-70FPS. My Graphics Card is a 6950 Brand New HIS Radeon ICEQ Its irrelevant though because its not a Reference card and it cant be upgraded to a 6970. My question is If I Overclock MY CPU with the TurboV EVO to a 3.2-3.4 Will i see Some FPS increase and im sure the temps will increae probably 50-55 But that's
Will I see FPS Increase IF I Overclock my AMD 1055t CPU from 2.8 TO 3.2
I have never overclocked anything so im SORRY!!
More about : overclocking cpu
You might try, but the change won't be visible, maybe minimum framerate will be increased, that would be noticeable.
And btw. I got his 6950 2gb iceq either and it's absolutely possible to unlock shaders, you just need to modify your own bios.
Ask the community
