Hi there,
Can anyone help me as i've exhausted all avenues i can think of!
I have a Gigabyte GA P55 UD6 motherboard which supports dual channel memory, I bought a Corsair XMS DDR3 3x2GB 1333mhz kit from Microdirect after assuring me it would work on this motherboard (he neglected to mention that 1 of the modules would be redundant on this board! which i later found out!)
The Problem i have is that my system is only using 2GB of the 4GB i installed, i have installed the 2 modules in the correct slots according to the the motherboard manual and in bios it shows i have the slots populated but only 2gb is enabled! and my OS is saying the same.
I've updated the bios to the latest version and have windows7 64bit. Apart from tryin different memory i dont know what else to do? can anyone help me please?
the CPU is an i5 running on standard settings if this means anything? im noob thanks
