Advice for a first time water cooling system
Long time reader of this forum but i would like some feedback from the community on this one as I'm finally ready to enter a water cooling setup for my gaming rig and i dont really want to make any mistakes with this computer. Currently running I7-2600k, 16 GB dominator RAM, 3x EVGA 570 SC, 1500 W Silverstone PSU, EVGA z68 FTW mobo in a HAF-X case. Now on to the speculation of what i want to setup for water cooling for the components are as follows:
XSPC Rasa RX 360 (rad/pump/res/cpu block)
3x EK 570/580 water blocks (EK-FC580)
Distilled water with a kill coil in res
8- 45 degree compression fittings for making the tubes have to do a little less bending
Koolance video card block spacers for in between each card to keep the loop going
Danger Den 1/2" ID 10 FT tubing
Arctic cooling MX-4 for thermal paste for cards and processor
finally Articlean cleaner for the gpu's and cpu
now what I would really like to find out is if this Rasa setup will power thru the full loop or would i be better off looking at a seperate pump/res/rad setup.
24 answers Last reply
More about advice time water cooling system
  1. You are going to need more radiators than that single RX360.
    A single RX360 can handle about 600 watts of heat using 2000 rpm fans. So, that taken into consideration:
    A GTX 570 (stock speeds) produces about 243watts of heat @ 100% load. You have three.
    243 x 3= 729 total GPU watts
    An i7 2600k (stock speeds) produces 95 watts of heat @ 100% load.
    729 + 95 = 824 total watts in your loop (not counting the heat from the pump, which is typically 15-30 watts on average, depending on pump)
    If you are going to be building a loop that substantial, I wouldn't use the XSPC X20 pump/res at all. The Rasa CPU block and RX360 rad are great, I just would get a better pump for a loop like that.
  2. HAF-X... I don't have much experience with those. The build looks similar to an 800D (Although I may be horribly horribly wrong).
    The radiator is good, but I suggest going with another 120mm Rad at LEAST.
    I second the upgrade for the pump. Four (?) waterblocks provide a fair amount of resistance in the loop.
  3. the HAF-X can only support up to a 360 rad on the top so to find a new rad and a pump/res combo any suggestions on the combo should i get a dual bay/dual pump setup or should i go a single Koolance with the lcd screen and goodies or go for just a plain res that can house 1 or 2 pumps? By the way trying to find everything on frozencpu.com and the product info is less than stellar trying to find a new rad that can dissipate that much wattage heat
  4. A dual loop isn't going to benefit you more than a single serial loop. In fact- a single loop will out perform a dual loop given the consideration you use the same radiators for the dual loops in a single large loop.
    And having dual pumps or dual loops has nothing to do with only using one radiator...this doesn't make sense. You'd need more than the single 360 regardless if you ran one loop or 2.
  5. ok so i need to go back to the drawing board then for this then thought i read enough to figure out the setup thanks for the help
  6. Put radiators on the front intake and the back exhaust in conjunction with the 360 on the top, and you'll be fine.
  7. front intake is not feasible HDD cage is there and is close to full w 2 raptors a WD black 1tb and 2 ssd's but i guess i could go with another rad hanging off the back then
  8. and if i were to add a rad to the back should i go another 120 or go to a 140 and how exactly would that setup actually be run? Does the out from the 360 go into the in on the one on the back of the case and its pushed from there?
  9. If I'm not mistaken, I'm sure you can put a rad where the 200mm fan is on the side panel.
    Just to clarify, just stick a 140mm Rad where your original 140mm fan is.
    Edit:
    Add a 140mm Rad. The order doesn't matter, but here is how I would do it. 360mm Radiator -> 140mm Radiator -> CPU -> GPU -> Back to 360mm Radiator.
    Oh, and look at these radiators, they have a very suitable pump, reservoir, and the radiator all in one package!
    http://www.swiftech.com/mcr-x20-drive-rev3.aspx
    Particularly the MCR320-DRIVE-R3 model.
  10. Having a rad next to HDD's isn't going to cause an issue...but if you don't have the space to remove or modify that area, then I understand.
    Please read through this thread: http://www.tomshardware.com/forum/269940-29-what-liquid-cooling
    We've had this discussion on the forum before. I strongly suggest reading through as many threads as you can as part of your research. We get dozens of people asking the same questions each week, so chances are- we've helped answer this before; possibly even recently.
    Edit: Also- please slow down and make sure you are posting relevant information and not posting several replies in quick succession. Use the edit functionality to add additional information to your posts if you need to update or edit. There is no need for this:
    and then only 4 minutes later:
  11. gotcha on the rad and i didnt realise there would be clearance for a rad on the panel but i do like to dust my pc out every other week or so and i think that would get in the way but like i said how would the tubing be run on adding a second rad to the loop
  12. 360mm Radiator -> 140mm Radiator -> CPU -> GPU -> Back to 360mm Radiator.
  13. You just add the tubing from one to the other...? I guess I don't follow your question, here.
  14. I'm assuming he wants to know the order of which they should be connected.
    It doesn't matter, but thats how I would run it.
  15. ^ Correct- loop order does not matter.
  16. Alright, I've compiled a list for what you should *At minimum* get.
    Radiator(s):
    XSPC Rasa RX 360
    and
    Black Ice SR1 140mm
    Pump:
    Swiftech MCP655
    Reservoir:
    XSPC Dual Bay Reservoir (You can put your MCP655 Pump in there for neatness. ;) )
    CPU Waterblock:
    Apogee XTL
    ALTERNATIVE:
    NOTE: I Have NO idea whether this will fit in your case without some minor modding.
    Rad/Pump/Res Combo
    Swiftech 360 Radiator with Reservoir and Pump
    CPU Waterblock:
    Apogee XTL
    Fittings/Tubing/Extras are completely up to you.
    I recommend compression fittings if you have the cash going for it.
    Use any sort of distilled water with some kill coils for the fluid
    Use UV tubing instead of dyes for both cleaning efficiency, life longevity, and it overall looks nicer.
  17. MCP355 or 35x would be just as good for that loop...and smaller. They make reservoirs that fit those pumps too. D5's are good, but they are big- if he already has space issues, I'd vote for the smaller pump. Just because it's smaller, doesn't mean it isn't just as good.
  18. I agree, but I only vouched for the pump because it could fit in the dual bay reservoir. :p
  19. They make single and dual bay res's for DDC pumps.
  20. thank you both for the input ill start looking at frozencpu to see what this is gonna run me now. Was also already planning on uv tubing and compression fittings and some other bells and whistles doing it right the first time is better than trying to cut corners
  21. FrozenCPU has some of the very best selection out there, but can be more expensive than other sites. However, it come down to selection vs. price in some instances. There are some retailer links in the WC sticky in case you want to look around and price shop.
  22. Again thanks ill take a couple days to look around and when im done ill put the compiled list up for you guys pretty sure i have a good idea of what to snag now appreciate the input.
  23. OK so i spent last night putting together a comprehensive list some of the items you guys suggested i snagged some i didnt but here we go.
    XSPC Dual 5.25 bay res with MCP655 pump
    Black Ice GTX Xtreme 360 rad
    Black Ice GT Stealth 140 rad
    2x1800 rpm 140mm fans
    6x 1850 rpm fans
    Scythe Kaze Q-8 8 fan controller
    Arctic Cooling MX-4 thermal compound
    Apogee XTL waterblock and 1155 backplate
    EK Geforce 570/580 GTX vga blocks(black version)
    1 each on the Koolance 1 slot and 2-3 slot spacings for the sli setup
    2x IandH Silver kill coils
    Compression Fittings- 2 straight 4 45 degree and 4 90 degree fittings
    3x Koolance inline coolant filter
    Hopefully this gives me the drop that I want with my system. Thank you both for the help
  24. Coolant filter? Why?
Water Cooling Overclocking Product
