APPROXIMATE PURCHASE DATE: As soon as I figure out what I need (a week?)
BUDGET RANGE: $600 - $900
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: SimCity 4 Rush Hour, X-Plane, web
PARTS NOT REQUIRED: kb, mouse, 17" monitor
PREFERRED WEBSITE(S) FOR PARTS: looks like newegg is good
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1024x768, 1280x1024
ADDITIONAL COMMENTS: I'm completely new to this, but can read and
learn, with a little guidance in the right direction. I've only used Macs, but for the money, it looks like a Windows machine will be best for what I want to do, plus be upgradeable instead of a one-time buy. Means learning a new OS. Means learning about the hardware. Ok then, if that's what it takes.
From what I've read here so far, this is my list:
AMD Phenom II X3 720 (1 GB?)
WD Caviar Black 620 HD (plus a 2nd ,hopefully cheaper, HD just for back-ups)
Radeon 4870 (1 GB?)
Corsair 650tx power supply
Antec 300 Illusion or NZXT Tempest or Cooler Master 690 Case
Vista with 7 upgrade
unclear on the DDR2 vs DDR3 choice and which motherboard, could use major advice there.
I want to be able to run a 6 year old program, SimCity 4 Rush Hour, that has a reputation for being a processor hog. All those commuting sims have to make route decisions, and the population can get into the millions. I guess a 64-bit processor can run an old program like that. And then X-Plane has detailed scenery that probably works the graphics card hard. The common thing to both these games is there's a large community making add-ons for them (roads, buildings planes etc.).
After I decide on the hardware, I'll have to figure out how to put it together, and then how to set up the software. At this point dealing with the bios and over-clocking sounds scary, but there must be places that explain it all.
Thanks for any help. Let me know if I left out something.
I'll go with the 4850 for $120, since I doubt I'll be upgrading my monitor. This 4850 1Gb card gets good ratings:
XFX HD-485X-ZDFC Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.com/Product/Prod [...] 6814150351
How you order the parts is up to you, but I prefer to order all the parts at the same time.
The Mushkin RAM has tight timings at a low voltage. Mushkin also makes very high quality RAM. I've also had good luck with G.Skill RAM. The most important thing is fast RAM with tight timings at a reasonably low voltage. If you find a G.Skill kit with similar specs as the Mushkin RAM, I'd go for it. Newegg's RAM choices have dried up a little lately.
That XFX 4850 is nice. I especially like the dual-slot cooler that exhausts the hot air outside the case.
Nice build from shortstuff. I did have to re-read the OP carefully to see why the second hard drive was included. Especially if you're still using the Mac, and want to transfer files, consider putting the second hard drive in an external case with USB and/or Firewire connections so it can connect to both of those systems. Make sure to format it with something that both can read (FAT32?)
I just made my first big decision. Ordered the AMD Phenom II x3 720 and Antec 550W TruePower combo that was suggested by shortstuff_mt. Hope to have it all ordered in 2 or 3 days days.
http://www.newegg.com/Product/Comb [...] mbo.233382 Thank you for the good ideas.
I didn't mention this in the original post, since it didn't seem to matter then, but besides my iMac, I have an XP music computer I had someone build for me a few years ago. It is using a 9 year old Compaq mother board, but it has a nice Audigy sound card and software for up-sampling CD files to FLAC. I haven't touched the XP software though, I wouldn't know how to do anything with it. I just turn the computer on and play music. There's also a WD IDE 80MB HD in there that I guess could be networked with the computer I am going to build, and use that as a backup.
There's nothing left of the old Compaq other than the motherboard. It has a Platronics DVD burner, an old 300W PSU, and it's in a pretty nice mini tower Silverstone case (M ATX I think they're called).
Guess I was thinking out loud in those last two posts. I'd gotten the idea that maybe I could use the old stuff, including the mini-case, for the new computer. But after doing some measuring, I saw that wasn't happening. But maybe I can move the Audigy sound card and the 80MB hard drive into the new computer.
I just finished ordering everything. Comes to $817 after all the combos, rebates, and shipping. Spent more on a case than I planned. but there was a coupon for $15 off the Antec 900. Spent a little more on the memory, but it may be faster and clockable, if I understand what was said earlier. I got a HSF I hadn't planned on, but the one that comes with the Phenom x3 sounds pretty bad, and after reading a few hundered reviews, I'm looking forward to at least upping the multiplier (whatever that is, to be learned next week). Do here's the list, maybe it'll be of some use to someone else working on a similiar system:
AMD Phenom II x3 720 Black
Gigabyte 770 MoBo
Mushkin 4GB DDR3
XFX Radeon 4850 1GB
WD Caviar Black 640 SATA HD
Samsung SATA DVD
Antec 900 case
Antec TP550 psu
Xigmatek S1283 HSF
Arctic Silver 5
Thanks for the help, here and at all the other threads like this one from the last few weeks. I've learned a lot, and now it's on to researching how to put it all together.
And one last item, evidently important if over-clocking using the Gig 770 motherboard:
Enzotech MST-88 C1100 Forged Copper Heatsinks MOSFET Cooler
http://www.newegg.com/Product/Prod [...] 6835708016 Adds about $18, with shipping, for total of $835 for this system.
