Yes No
Ads
Tom's Hardware > Forum > Overclocking > General Discussion > [Solved] Help please? PC randomly reset/restarting
Forum Overclocking : General Discussion [Solved] Help please? PC randomly reset/restarting
Best answer from arthurh.
Hi Community,
I recently tried to see what I could push my GTX 580 up to and clocked it up to about 890 Mhz Core Clock at 1.1V. This was stable for 4-5 hours but then my PC reset and my settings were back to default. I assumed this was unstable so I brought the Voltage and Core Clock down about 0.3V and 50Mhz respectively. The problem continued to persist after about 2 hours of play on BF3. Not wanting to corrupt anything, I reset my settings to factory and continued on. The problem is, the resetting continues at seemingly random intervals. This has happened about 6 times in the last 2 days. Any ideas why this might be? My card never got over 70 C and runs idle at about 28 C.
i7-2600k
ASUS Direct CU II GTX 580
8 gb G. Skill 1600
P8P67 pro
Corsair HX750
Can anyone please help me?
gbrew345
Reply to gbrew345
I hear bf3 has some issues regarding this as it is. Have you verified this at their forum? Is there some one here that can confirm this, I have not picked up bf3 yet. I have a few buds that are complaining about this, and one in fact that has the same issue you do.
------------------------------ AMD Phenom II X4 955 @ 3.9Ghz//GIGABYTE GA-970A-UD3//PowerColor AX6850//Antec EarthWatts 650W//Hyper 212+//Ripjaws X Series 2x8GB//Spinpoint 2x1TB
Reply to slcmike
Its not only when playing BF3 that it restarts, even during idle sessions or internet browsing the computer will randomly reset.
Reply to gbrew345
Do you have your 2600k OCed?
------------------------------ http://valid.canardpc.com/cache/banner/1091644.png
Reply to arthurh
no, its stable on normal. I reinstalled the drivers and it hasnt happened again yet so i think im safe.
Reply to gbrew345
Best answer
Sounds like you found your problem alright.
If you OC your GPU too much and it crashes it will usually corrupt the video drivers.
Reply to arthurh
Your welcome but I think you solved your problem yourself my friend! :D
Reply to arthurh
Hey I am having te same problems and I have relatively the same parts and having a hard time trying to find the drivers. Do you mind if you could send a link with the divers or if you dl off cd. Sorrg in relatively knew to this
Reply to Walters_56
donot oc your gpu to that extent where performance is compromised.
Reply to ANINDYA_50
There are 1480 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Does a computer NEED ram?
By Motopsychojdn, 3 hours ago:
A Pc will not function without ram, simple as, can you post the model/make of your Pc and...
Best offers
Top experts
