Hi, I've just put together my friend's computer. At first it all seemed fine, but then I realised that after switching it on, 10 seconds later it powers off. I thought it may be an overheating issue with the cpu heatsink, so I took it all out and now have the PSU and MOBO assembled outside of the case, which by chance I thought maybe the RAM is faulty. It is 2*2GB sticks, so I tried with 1 stick and it works fine. Tried using the other stick on it's own, and that too works fine. I've also tried each stick in each slot, and they work in either.
Specs:
Asus P5KPL SE motherboard
Coolermaster RE 460 PCAP A3 powersupply (460w)
Corsair 2*2GB 800mhz ram
Core2Duo E7300 I think
Is the powersupply not substantial enough? My computer has a 500W, 4gb ram, 8800gt, E7200 2.53ghz etc and runs just fine........
Specs:
