Tom's Hardware > Forum > Homebuilt Systems > New System Build > Boot problem - new build
Build-
EVGA E758-A1 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model TR3X6G1600C8 G - Retail
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
EVGA 896-P3-1173-AR GeForce GTX 275 FTW Edition 896MB 448-bit DDR3 PCI Express 2.0 x16 SLI Supported Video Card - Retail
When it starts it shows the HD's in the list. then the next screen it says "Detecting drives, Done. No drives detected"
then that goes away and it shows my DVD drives name there. Next it says "Boot failure, please insert system disk and press enter" I put in windows CD, press enter and it just repeats put system disk in.
Help please!!
I went through the sticky on top, it's none of that.
Sponsored Links
In bios, is your DVD drive the Primary boot drive? If not change that. Make sure the SATA cable is plugged in correctly.
Reply to radiowars
I think I found the problem with your response. I dont have a sata DVD Drve, does it only use sata for DVD? I have mine plugged into the IDE. should it still work with IDE?
Reply to Akkah
I switched the boot order in setup, still same problem
Reply to Akkah
Problem solved! Master/slave jumper was wrong on the drive.
Reply to Akkah
There are 1196 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
