Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help repair graphic card(may be hardware repair)
Forum Graphic & Displays : Graphics Cards - Help repair graphic card(may be hardware repair)
hi,i have a problem with my graphic card:
it works good but when i want to play a game (any game),after about 10 minute it hangs and there is no respond from my computer and i have to reset it.
i have changed my windows and also changed my driver.
i am sure that it is a hardware problem.
could any expert please say how can i fix it?
my mainboard is:asus p5kpl/1600
my graphic card:gigabyte 8400gs
http://xs343.xs.to/xs343/09383/gc1299.jpg
thankx in advance for your help.,
Sponsored Links
We are going to need the rest of your system specs as well. It could be a power problem or an overheating problem.
Reply to FallenSniper
That card is simply terrible for gaming so this sounds like a good excuse to upgrade. You can get a card several times better for as low as $50.
Reply to jyjjy
Download a copy of CoreTemp. In addition to monitoring CPU temperatures, it also looks at GPU temperature. That will help you spot any overheating problem.
Reply to jsc
ok.but first i want to say what cause this problem:
i installed "speed gear" software and then my computers hanged, i reseted it,then my graphic card came in 4 bit mode and when i installed it computer could not recognize it.i changed my windows also my driver but the problem still was there.
finally i removed the battery from mainboard and reseted the bios.
then i installed another windows.everything was good since i know this problem that i wrote in first topic.
i changed
my system:
cpu:intel e5200 2.5gh
mainboard:asus p5kpl/1600
ram: 2gig
power:450w ?
Reply to massiha
I just looked up speed gear and that software looks dodgy as all hell but I really doubt it could've actually broken any hardware.
Check for overheating like these guys are saying but even if it is the best you can do to fix it is cleaning the card.
Reply to jyjjy
hi again,i check my gpu temprature,it goes to 87 until 15 minutes playing in windowed mode of game (flatout and...),but in the full screen mode my graphic card hangs in about 3 or 5 minutes.
i do not think this problem is because of temprature,i think there is something wrong with my graphic card.
plz do any body knows how can fix it,may be i can repair it if u say where the problem is.
thanks.
Message edited by massiha on 09-17-2009 at 01:32:47 PM
Reply to massiha
If your graphics card is dying, there's nothing you can do to fix it. Dead graphics card is just a good excuse to buy a new one.
87 degrees is quite high and it likely gets higher when pushed to full screen. It is overheating. Make sure the fan is working. If it is try cleaning the card out well as cards can accumulate dust that will prevent proper cooling. If that doesn't work it's time for a new card.
Reply to jyjjy
If it is the one in the pic then get a cheap bay fan to blow cool air on the card and get a tube of arctic silver5 to replace the dried out crap they use on most cards. Thermal compound can dry out over a few months if it gets very hot so new compound in addition with better airflow will help your card. All together it might cost $10-$15 but if the card is way past repair don't count it as a loss use can still use the bay fan with the new card. I use a vantec duel 80mm with my 9800gt and my 8800gtx so both cards (using one or the other) don't go over 60c under load.
Reply to nforce4max
i have done what all you said but problem still is there.
i've played most of the games with this graphic card and there was no problem before even when i was playing for more than 6 hours,
so i think my graphic is somewhere between earth and sky,
i have noticed that my graphic card still has warranty,so i want to send it to warranty.
but another question :
do you think that i write all the thing that is happening or no (they will know the problem themselves)?
sorry for my bad english.
thankx
Message quoted 1 times
Message edited by massiha on 09-18-2009 at 07:31:53 AM
Reply to massiha
+1. Something like this should help. If not, then send it back to the manufacturer. They will have you tell them what the problem is as well.
yeah that works well we did the same with some old 9500gt with silent heat sink --stick a fan with 1 or 2 screws just hook it on to the hs and let it cool :P
Reply to viper200
thankx
Na they won't know plus they are obligated since the warranty is no voided so good luck and maybe you will get a newer model hehe. :D
Reply to nforce4max
There are 856 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
