Gtx 260 not enough power connectors? - FIXED
Last response: in Components
November 19, 2009 8:41:28 PM
Hi,
I have an alienware area-51 7500-r5 with a 700 WATT OEM ATX PSU REV2 power supply.
Now, i am trying to connect a gtx 260 and for the life of me i can only find a single 6-pin connector spare..and no spare 4-pins
Do i just not have enough spare pins to power the card or am i missing seeing one inside my case?
if this problem is anywhere else, i missed it so sorry if its a common issue..
thanks
November 19, 2009 9:23:45 PM
Try to look up your PSU and check how many 6-pins/ 6+2-pins it comes with.
if its not two, i'm sure there's some molex to 6-pin adapters out there somewhere
m
l
November 19, 2009 9:39:07 PM
thanks cooler, that issue is solved, on to the next! :p
m
l
November 23, 2009 3:02:51 AM
np
select me as your best answer so i can get some badges :D
m
l
