Hey guys, i have an issue with my ram atm, bit of a weird one.
Just to make it clear i have reseated my ram a number of times tried it in different slots etc.
Ok so basically i have a Core i7 950 Overclocked to 4.05ghz ram is overclocked to 1754mhz at 1.65v, Asus Rampage 3 Formula mobo, and 12gb of GSkill 1600mhz ram. Windows 7 64bit, cpu is cooled by a xspc rasa rs240 kit. double rad.
So atm my bios at post and windows 7 only see 8.00gb. Before i updated my bios i was able to get 12gb of ram to come up but i dont wanna roll back the bios at this point.
For some reason, CPU-Z is showing that i have triple channel memory installed and it is also showing i have 12288mbytes installed.
But for some reason the memory DRAM frequency is only around 877.0mhz?... shouldnt this be up around 1600mhz?.
Readings are as follows.
CAS: 9.0
tRCD: 9 Clocks
TRp: 9 Clocks
Tras: 24 clocks
trfc: 88 clocks
CR: 2T
Piriform Speccy also gives me a reading of 12.oGB Triple Channel DDR3 @ 876mhz 9-9-9-24 Readings.
But it is giving me funny readings.
Memory slots
Total memory slots 6
Used memory slots 4
Free memory slots 2
Memory
Type DDR3
Size 12288 MBytes
Channels # Triple
DRAM Frequency 877.0 MHz
CAS# Latency (CL) 9 clocks
RAS# to CAS# Delay (tRCD) 9 clocks
RAS# Precharge (tRP) 9 clocks
Cycle Time (tRAS) 24 clocks
Command Rate (CR) 2T
Notice how it says total memory slots as 6 which is corrent, but used memory slots as 4?.
I have all 6 slots taken up with 2gb sticks in each one.
This is doing my head in, wtfs going on. It cant be faulty ram right?.
Ok so is there anything i can try to change in the bios?.. maybe some voltages or some frequency's.
Would boosting my NB frequency help in any way?...
Its so anoying. Any help will be great.
Cheers.
CAS: 9.0
tRCD: 9 Clocks
TRp: 9 Clocks
Tras: 24 clocks
trfc: 88 clocks
CR: 2T
Memory slots
Used memory slots 4
Free memory slots 2
Memory
Type DDR3
Size 12288 MBytes
Channels # Triple
Cheers.
