Hey guys,
I am in the middle of creating a new build that some guys over in the custom build thread have been giving advice on. I did a lot of research before hand and I heard a lot of good things about the Intel 320 series. With a current $80 rebate, I can get the SSD for $320 at a 160 GB size. One of the guys looking over the build suggested the Crucial M4 instead because it was only $230, granted it is only 128 GB. So for those that know a good amount about SSDs, which would you prefer in your build? My other specs that you may need to know are....
MOBO
GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #:GA-Z68A-D3H-B3
Item #:N82E16813128502
$129.99
CPU
Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600
Model #:BX80623I72600
Item #:N82E16819115071
$299.99
RAM
Kingston HyperX 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K4/16GX
Model #:KHX1600C9D3K4/16GX
Item #:N82E16820104169
Return Policy:Memory Standard Return Policy
$169.99
So what are your thoughts? All feedback is appreciated. You can assume that both prices are affordable and I can make due with the 128 GB. So which drive is better. And if the Intel is better, is it worth the extra money? On my current computer (which is 3 years old), I have a 160 GB raptor drive, with a 1 TB media drive behind it, and of that 160 GB, I am currently using 102 GB (although there is probably a fair amount of garbage I could uninstall or get rid of). I appreciate all feedback!
MOBO
$129.99
CPU
$299.99
RAM
$169.99
