CPU: Intel Core i7 920 MOBO: Gigabyte GA-EX58-UD4 PSU: Corsair 620HXEU Memory: Crucial 6GB kit (2GBx3) HDD: WD 1TB Green Power WD10EADS Cooler: Noctua NH-U12P SE1366 Case: Antec Solo GPU: MSI 512MB 8400GS DVD: LG GH22LS30RB
what do you think? i put a lot of thought into it before asking you guys, but i'm no expert so at this point any corrective advice will be greatly appreciated!
i'm mostly not 100% sure about the HDD, cooler and VGA... plus that Crucial memory was chosen due to my budget, but i've not read anywhere that it'd be a bad choice either... or would it?
thank you
Message edited by sethh on 08-29-2009 at 10:30:40 AM
I have heard Crucial is doing better with DDR3 i7 memory, but I still don't trust them after the mess they made with the DDR2 over the last year or two. Crucial would probably be my last choice.
Here is another choice: http://www.ebuyer.com/product/144085 Modular and very quiet... You mentioned the 620HXEU so I guess you are in EU somewhere
hmm, i do not know a thing about Crucial's past. i haven't been PC-shopping for years now and am totally inadequate actually, but my googling skills have got me thus far. what memory would you recommend instead then? is there anything better that doesn't cost twice as muchl?
about Corsair, the place i was intending to buy the build at has the CORSAIR 620HXEU (620w 120mm fan atx eps12v) and next up from that is the CORSAIR 750TXEU (750w 140mm fan atx), no 650TX in between. would it be worth the trouble of finding another place that sells the 650TX or would one of those be good? (i read here that the 750TX would make more noise under load than the 620HX though.)
Message edited by sethh on 08-29-2009 at 08:50:05 AM
Check out these DDR3 Triple channel Ram, you want to go with Cas7 or Cas8. OCZ 6Gb (3x2GB) DDR3 1333MHz Memory CL7(7-7-7-20)
http://www.ebuyer.com/product/152747
Would suggest this 1TB HDD over your selection mainly due that the one you selected will slow down rpm. Western Digital WD1001FALS 1TB Black Hard Drive SATAII 7200rpm 32MB Cache £65.99inc vat Free Delivery http://www.dabs.com/products/weste [...] 0000-50473
Would go with the Corsair 750w PSU, mainly due to upgradable for future needs. Comparing the price between the two below. Corsair 620W HX Modular PSU - ATX12V v2.2 APFC £89.84 inc vat Free Delivery
http://www.ebuyer.com/product/114941
Would also suggest one of these Cases with Free Shipping @ eBuyer. Coolermaster HAF 922 Mid Tower Case £89.52inc vat
CM Storm Scout Case - 120mm and 2x 140mm Fans Included £74.97inc vat
Antec 900 Nine Hundred - Gaming Case with 200mm Top Fan £74.98inc vat
Antec 902 Nine Hundred Two Black ATX Case £85.99inc vat
Yoosty, digital audio workstations need to be quiet.
The 750TX would not be a good choice due to noise, and any large PSU is not needed as this is not a gaming build.
The Noctua fans are quiet. You can mount two on the cooler and run them at half speed and you won't hear them at all.
Sethh, get the Corsair 650TX or the Enermax I linked. They will serve you well in the future as well. See the reference I provided for their silence ratings.
