Trying to stay close to $1500 for my build and I'm finding myself slightly over. I'm going for a core i7 920 with EVGA gtx 275 because of the option to step up at a later date. I want to keep my options open for SLI so I will need a board with at least 2 pci 16 slots.
I saw the $169 ASRock board but it was sold out on newegg so I put down the EVGA board here. I didn't really see anything else between the two in price ranges that covered what I needed and got positive reviews.
Here is what I have so far.
Scythe MUGEN-2 SCMG-2000 120mm Sleeve CPU Cooler
Western Digital Caviar Black 640GB 3.5" SATA 3.0Gb/s Internal Hard Drive
Hanns·G HG-281DPB Black 28" 3ms Widescreen LCD HDMI Monitor Built-in Speakers
SAMSUNG Black 22X DVD+R 8X DVD+RW 22X DVD-R 16X DVD-ROM 48X CD-ROM 2MB Cache SATA DVD Burner LightScribe Support - OEM
1ST PC CORP. 12" 8-pin EPS extension cable Model CB-8M-8F - Retail
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Retail
OCZ OCZ3P1600LV6GK DDR3 PC3-12800 1600MHz 6GB Platinum XTC Triple Channel Kits
COMBO
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
for minus $20.
COMBO
EVGA E758-A1 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard - Retail
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail
for minus $15.
Any suggestions on how to shave 100-150 off this beast without losing much? My idea was to find a comparable motherboard at a cheaper price or to downgrade my PSU to the corsair 750TX. My only concern about that though was whether or not it would be enough power if I chose to get another gtx 275 or upgrade to the gtx300 series.
Also, will the single gtx 275 be able to handle the 28" monitor until I can get a 2nd one or upgrade it?
Thanks Will be ordering sometime today or tomorrow.
COMBO
for minus $20.
COMBO
for minus $15.
