Hey guys,
I've been doing a fair amount of research on Overclocking my E6750. I have a P53n-E SLI. I'm going to be upgrading to a new mobo and new CPU in maybe half a year or something when I get a little more cash available, so I'm looking to do some overclocking...not much, just whatever will give me a slight boost for Skyrim. At any rate, I looked online about doing this and I found some decent guides with people who had the same CPU, but different MOBOS. When I actually went into the MOBO bios, everything looked QUITE different. I had an option for some sort of "Hypertweak" thing or something *I should have written the name down* and it allowed me to change the autoclock options to Manual, Auto, AI Overclock, AI N.O.S. So, I went to manual and looked around...realized I had NO idea what these settings meant because they seemed so different, and then decided to dabble with AI Overclock. It allowed me to set my overclock % to 5, 10, 15, 20. At 20, my computer shut down soon after it booted..obviously that's too hot. I moved down to 15 and it seemed to work out, but I'm running ORTHOS for stress tests and using AIDA64 (Everest) to monitor temps. At 15, the idle temp was over 60, so I decided to knock it down to 10%.
So at 10 % I'm now running 2200.mhz x 6 so I guess thats 2.8. Not a huge jump from a 2.6..but whatever. Now, heres my issue.
The CPU temp for core 1 is hovering around 59-60 *sometimes going as low as 55*. and the CPU temp for core 2 is around the same. When I stress it using the Orthos blend option, it gets up to about 80. So far, it didnt go higher. I did the blend for about 2 minutes and there was no shutdown.
I'm using a http://www.newegg.com/Product/Product.aspx?Item=N82E16835106061 , so definitely not a stock cooler.
Now, my problem is that...I've been looking around online and people have been giving me various responses for what the temp should be under stress. People are suggesting I should be under 60 (right now its saying 56...so I dont know what the heck is going on lol) during idle and below 80 during stress...some are saying below 75 during stress, 72(which is the limit stated on this website for the E6750) etc. I realize that the CPU type makes a big difference.
If anyone could give me any advice i would greatly appreciate it. Worst case scenario I can bump it down to 5% and see what happens. I'm assuming that this auto-program its using is probably doing something a bit more than I could do on my own, but I figured I'd ask and see before I started tinkering around with settings by trying to match them up with settings from other guides.
Thanks a bunch
Thanks a bunch
