Hello I'm running an ssd for the first time and having problems. I got a Crucial M4 64GB drive.
The computer won't hibernate and sometimes it won't even completely shut down. Worse yet, the computer crashes blue screen pretty often. I don't know how to get the error codes off the blue screen, b/c I'm kind of a newb. Also, many Windows updates are installed, but I cannot get Win 7 service pack one to install which I hope would fix the crashing! I have used Windows Update trouble shooters to no avail.
I have installed Windows 7 64 bit home on it. I made sure that no other storage was hooked up during installation. Since I have installed many windows updates, a few drivers including graphics, avast free antivirus, and I copied Starcraft 2 over from another drive (a drive that I reconnected after installing Windows 7).
I have many guesses as to what the problem could be, but I won't share them for now with one exception. When I was installing the M4 I unplugged the sata cord from my DVD drive that was in the one and only sataII port. When I unplugged it the little terminal that the sata cord plugs into came off with the cable. I was able to fit the terminal back on the pins and plug the M4 into the mobo, but I am concerned I may have done some damage. That said, windows did install and it doesn't explain why service pack 1 won't install.
Also, I've read conflicting reports on using hibernate and standby while using an ssd. Is there a current or definitive answer on best practice?
Here is some additional information about my rig: Most of it was purchased in August 2006. I know it's a dinosaur and I am hoping an SSD will breathe some new life into it b/c it still does everything I want it to.
AsRock 939 dual-sata2
Amd x2 3800+
2 GB GSkill DDR400
EVGA Nvidia 9800gt
iGreen 500W power supply
Thanks,
Bigdayve
Amd x2 3800+
2 GB GSkill DDR400
EVGA Nvidia 9800gt
Thanks,
Bigdayve
