hi !
while i was working (office activity so not very HD work/copy) on my computer, i have a strange freeze problem : my browser (where i worked) was frozen . It was the hard drive where the mozilla cache was.
After a short moment i quickly understood my whole hard drive will go failure !
and i heard strange noise : run and switch off motor/head/power.
now my HD does not run at windows boot... (i'm crying my heart of 750GB of personal data !!)
i got back the HD off the case and now i'm trying it with USB access using usb-sata cable connector.
When i switch on the HD, it's running a very short time (5s), but the OS (win7 x64) did not have enought time to rightly discover it (and all its partition) because the drive always switchs off on first USB drive detection !
then i unplug and replug the HD and the drive can very hardly (random i guess) been recognize by windows. Only one time i success to see again my partition/files list but not enought time to copy the files.
what should i do know ?
do you think if i access it with linux live CD, the HD may work better (enough time for a backup) ? Maybe linux will check/boot/discover the USB drive more quickly than windows does ? Maybe the HD mecanical system is less solicited under linux ?
thanks for help (sorry for my expression, i'm not born english)
my hard drive is :
brand : western digital
model : WD7500AAKS-00RBA0
DATE : 04 jul 2007 (so almost 4 years)
DCM : HBRNNA2ABB
SN : WCAPT0126312
my hard drive is :
DCM : HBRNNA2ABB
SN : WCAPT0126312
