Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > AGP 4x/8x speed very slow
Forum Graphic & Displays : Graphics Cards - AGP 4x/8x speed very slow
My problem is that when I turn AGP speed in catalyst control center from 0x to 4x or 8x the screen updating speed goes extremely slow. Any idea what should I do?
My graphics card is Radeon 9250 and motherboard asrock K7S8X R3.0. They both support AGP 4x/8x. I've set the right speed from my bios too. I use native resolution of 1980x1080x 60mzh with hdmi cable. Graphics card driver version is 8.252 which is what ati recommends. I've also installed the motherboard's AGP-driver.
Sponsored Links
Have you tried turning the resolution down to something a little lower and less native?
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
1920x1080 is probably too much for that card and AGP just plain sucks. I've had problems similar to you on my old AGP rig: 8x AGP was a no go, it made the system slower than at 4x AGP and caused all kinds of errors.
Upgrade to PCI-E as soon as you can, even a PCI-E fossil such as the Geforce 6600GT beats the 9250.
------------------------------ CPU: Intel Core i7 920 @3.2Ghz, MOBO: Asus P6T SE, RAM: 3x 2gb OCZ Platinum OCZ3P1600LV6GK, GPU: Sapphire HD 5870, PSU: Corsair HX520W, HDD: Seagate ST31000528AS 1Tb 32mb, COOLER: Scythe Mugen (S775 version), CASE: Coolermaster CM690
Reply to Gulli
by updating slow, do you mean the screen refreshes slow? or games update slow?
What is the rest of the system. Higher resolutions do take more power in general.
A 9250 should be able to do it as i have a GF4 MX400 system that runs 1920 x 1280, but not over HDMI. HDMI has too much overscan(on my screen at least, not all are like that) for my liking.
With 512 MB of memory, that computer has a slow top down wipe to close apps, but with 1gig its fine.
Message edited by nukemaster on 09-20-2009 at 05:22:35 PM
------------------------------ http://i33.tinypic.com/sw3a5y.png
http://tinyurl.com/26uxxb - C2/i7 Temp? http://tinyurl.com/cj3pw - VGA power?
http://tinyurl.com/5v55wk - C2 Mem performance? http://tinyurl.com/6pmbke - SLI/Xfire?
http://tinyurl.com/yfmxdc9 - Part Guide?
Reply to nukemaster
With omega drivers the speed seems to be normal with 8x AGP speed. I wouldn't want to buy new computer just for normal windows use since I don't play games etc.
By slow I ment screen refresh rate when doing normal desktop use. It's same as before installing any graphics card driver at all. I've Duron 1.8g and 1.5g memory. Processor and memory load are normally quite low so they shouldn't be a problem.
Reply to Anonymous
Well, as long as you got it working.
Reply to nukemaster
There are 932 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
