G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
An error at boot-up:
Fatal Execution Engine Error (0x7927baca)
When you press the OK button, the following message from
backupnotify.exe comes up:
Application has generated an exception that could not be
handled.
Process id = 0x6b8(1720), thread id = 0x6bd(1724)
Click on OK to terminate the application.
Click CANCEL to debug the application.
When you click on CANCEL the following message is
generated:
Registered JIT debugger is not available. An attempt to
launch a JIT debugger with the following command resulted
in an error code of 0x2(2). Please check computer settings.
cordbg.exe !a 0x6b8
Click on Retry to have the process wait while attaching a
debugger manually.
Click on Cancel to abort the JIT debug request.
This error arose when I was trying to recover my new HP
computer (hp pavilion a 320n) purchased on July 21, 2004.
It seems to have arisen because of the HP
printer/copier/scanner (hp psc 2175 all-in-one) connected
to my computer... although a similar error was generated
when I loaded my Kodak EasyShare CX4300 digital camera
software. It was circumvented by following what the Kodak
webpage suggests for such an error, i.e.
close the Kodak icon in the tray
go to My Computer
select c:>Program Files > Kodak > Kodak EasyShare Software
Right click on the Catalog folder and select rename
change the name to CatalogOld
Then restart EasyShare software.
This work-around was successful. I need a similar thing
for the HP software.
Anything you can say or do to shed some light on this
problem would be much appreciated.
All the best
handled.
generated:
cordbg.exe !a 0x6b8
debugger manually.
go to My Computer
All the best
