Hey guys,
So I installed 2x 120mm side case fans as intake today and they make a huge amount of noise. I took it off the side case and left it standalone and they make almost no noise. I think the problem is that there are these grills on the side case that kind of blocks the air, which makes the fans make those loud noise (drives me crazy after 2 minutes). Also, on exhaust it makes no noise as well.
This is the case and the side of it I have. Any ideas on what I should do?
