this is my new system spec..
MSI 770-C45 AM3 AMD 770 ATX AMD MOTHERBOARD
89.99
XFX HD-485X-ZDFC Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0
10.49
OCZ XMP Ready Series 6GB (3 X 2GB) 240-Pin DDR3 SDRAM DDR3 1600
119.99
AMD Phenom II X3 720 2.8GHz Socket AM3 95W Triple-Core
149.99
This is my problem..the motherboard (MSI 770) has 6 audio inputs..and on my current system the motherboard has 3 audio inputs..so if i put this motherboard in m case..it wont fit? i have small case..it came when i bought the computer..what should i do? is there like a face plate for the case that i can change so i can put in this new motherboard ?
89.99
10.49
119.99
149.99
