Tom's Hardware > Forum > Homebuilt Systems > New System Build > Q9550 or i5 750 Gaming/Multimedia Build Help
Forum Homebuilt Systems : New System Build - Q9550 or i5 750 Gaming/Multimedia Build Help
Hi All,
Im looking for a new build for Gaming and Multimedia, But im not sure on which exact chip to use.
Im either looking at the Q9550 or the i5 750
Here are the 2 builds
CPU : Intel Core 2 Quad Q9550
GPU : VGA (ATI) 4890 OC 1GB Gigabyte
Monitor : 23.6" WS LCD Samsung 2494HS
HDD : 3.5" SATA 1TB 32MB Seagate
Cooling : Noctua NH-U12P
RAM : DDR2 4GB
MOBO : Gigabyte EP45-UD3R
DVD : Blu-Ray Combo Pioneer
PSU : Thermaltake ToughPower 600W
Case: Antec 900 v2
or
CPU : Intel i5 750
RAM : DDR3 4GB
MOBO : Gigabyte EP55-UD3R
Case: Antec 900 v2
Which would be the better gaming machine, Would go the i7 but cost it pretty high, and so are the temps.
Thanks for the info in advance
Sponsored Links
http://www.tomshardware.com/forum/ [...] ild-advice <--- What's your budget, etc... ?
------------------------------ "God invented Google so you would stop asking stupid questions."
Reply to Why_Me
I would go for the i5 because of the new socket.
Reply to ColMirage
Sorry didnt see the above thread.
The PC will be used for Gaming and movies.
The cost is around $2000 AUD
So one or the other above or close, Im leaning towards the i5
Reply to dzrbenson
i would recommend i5 system,i5 processor are way much faster and bette rthan core 2 quads,they have L3 cache,integrated memory controller and new instructions there's no doubt you should go with i5
Reply to cauchy2k
I have a Q9550 - great chip. But if I were planning to build now, I'd wait and see what the reviews and tests show and go with i5 or i7.
Reply to jsc
There are 948 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
