Hi, I recently purchased two Gainward GTX 260's GS for my system:
Evga 790i SLi FTW
Q9650 3.0Ghz
CORSAIR DDR3 TW3X4G1600C9D 4GB RAM
Windows XP SP3
Nothing on the unit has been O/C'd as yet and i was planning to start after installing the mobo yesterday. However, (even prior to the mobo installation) I am having some issues with the graphics cards on NFS: SHIFT. This game is probably the most graphically taxing game I own and what happens is that 10/15mins into game play the screen will go Black on/off about 3 or 4 times and then the image distorts creating artefacts, green and pink pixels, vertical lines as it switches itself on/off as if trying to change resolution.
GPUz doesn't show either the cards GPU temp go beyond 79c & CPUz shows the CPU cores around 52c. I always put both fans on 100% when playing NFS Shift & yesterday took out the sound card and using the mobo inbuilt just to give the cards more breathing space (but problem still persists).
I have also uninstalled the drivers (using driver sweep) and reinstalled the latest drivers from Nvidia and then the beta drivers I found posted on Gainward site from only a week ago. Still the same problem.
I am not sure what the problem is as when I switch off the pc everything returns back to normal. When I run Benchmark 3D, no issues arise there. Is it a fault with the card/game/cpu/ram/drivers??? Any help/advice would be most welcome. Thanks!
I have only played GT Legends, GTR2, Race 07 and Flight Simulator X on the system with no issues. All are older games however I may do some testing with FSX tonight and max out the graphics and see what happens. Previously had a 8800GT and left the graphic settings pretty much the same on installing the GTX 260's.
I am going to get a copy of ARMA2 and again put the settings up and see what happens. I think i may need to run the cards individually & in SLi to see if its a particular card or the Sli bridge.
Okay did some extensive testing yesterday using ARMA 2 & NFS: Shift. With ARMA2 I could pretty much maximise the settings and run the game without any fault. The temperatures of GPU around 63c & CPU 61c (I need a new cooler for the CPU as this is stock and I think not enough when I start to oc).
I then tested NFS:
1 with card 1 only while card 2 remained in the case unpowered. PROBLEM OCCURRED
2. with card 2 without card 1 in the case = NO ISSUES
3. with card 1 without card 2 in the case = NO ISSUES
So it appeared even though the gpu & cpu temperatures are fine the heat generated is causing the fault elsewhere. So I installed both cards and increased the 2 fans on the case to around 80% (sounded like a plane taking off) & theer was NO ISSUE.
Now I need to find an optimum fan level for the PCI Cage & HDD while gaming that will run with no issues but not be as loud, or find out what it is that is causing the problem.
