Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Asus > New power supply for A7V600
Forum Motherboards & Memory : Asus New power supply for A7V600
does the ASUS A7V600 motherboard use the -5.0VDC rail? the ATX spec was changed and modern power supplies do not have that line populated. need to know if they will still work with this mobo. thx.
Reply to stephemm
Yes. Any decent atx ps should work; some have 24 pin connectors with 4 that can break off for older boards. Mine came with a 24 to 20 pin adapter, which also works well.
Reply to o1die
Just a follow up for anyone that cares. ASUS came back with a very terse answer saying "yes, you need to use the old power supply." My old power supply would not work with my desired configuration so I experiment to find out for myself. I cut the lead for the -5V rail and let it run for over a week. No obvious issues so I ordered a new power supply (ATX 2.2). It, too, seems to just work and it powers all of my new devices.
Kudos to the tech support guys at PC Power & Cooling for giving me way more insight than ASUS.
Reply to stephemm
There are 2187 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference between 2133 (O.C.) and 2133 for DDR3 RAM.
By stickg1, 14 hours ago:
Nice CPU, you can use 2133 RAM, you will have to manually set it to that speed in the...
Best offers
Top experts
